Rom Straßenbahn in Holz und Messing
niczano
Beitrag von niczano »
Hallo! My name is Niccolò, I am Italian but I have been living in Sofia for the past 5 years.
Like all of you since childhood I have always been very fond of trams. In particular, the old trams, those made of wood with a very high floor, with a wooden roof lined with tar.
I had love at first sight when I was 5, when in Rome I saw for the first time a tram type "MRS".
As with many of you, this passion coincided with the desire to represent the trams I like.
I started as a child to model a tea box, then to make cardboard models, then I worked plasticard then brass. Each time, however, there was something that did not give me satisfaction. Too many compromises and modellistic "standards" to follow.
After a few years from the latest models done, thanks to the lock down, I decided to try again.
In the era of 3D printers that reproduce everything with extreme precision, it can seem really stupid to play with your hands again, creating models without the aid of prints or laser cuts.
However, this is not the case if the idea is to do something different.
Here my idea is to create H0 models looking for realism instead of geometric precision.
Starting with the materials. My intention from the beginning was to reproduce the Rome (my city) trams of the first half of the 20th century, consequently the only materials allowed are wood and iron. No plastic (except the windows where I use 0.8 mm trasparent rigid pvc).
The constructive principle must then reproduce the constructive principle of the real tram. So, in my case, a frame of wooden beams to which iron panels (brass or copper) will then be "nailed".
The whole car, therefore internally and externally must follow the original. So, for example, the roof with skylight, in its internal part must reproduce all the staves and beams that characterize it from life.
Finally the functional part.
I remember for years I wondered how it was possible that man arrived on the moon but that 100 grams of h0 model could not be propelled by an engine that is not as big as that of a kitchen blender! They told me there were small engines, but they didn't have torque.
Today, thankfully, thanks to the Chinese friends, I met these fantastic coreless micromotors, extremely precise and fairly powerful and above all capable of a footprint that makes them invisible in the cabin. For the lighting, instead of the usual pre-built strips, the idea is to insert the (orange) LEDs one by one in balsa lamp holders (obviously I'm talking about the internal lighting).
In short, this is the premise, I don't know if I'll be able to make it happen, but the important thing is to try.
I am writing on this forum because the German tram modellism is the Marakana for every model maker in the world :wink: .
Here are the first photos of the "project" in progress:
Re: Rom Straßenbahn in Holz und Messing
Beitrag von Robin »
Caro Niccolò
Danke für die sehr schönen Bilder dieser beachtenswerten Modelle, eine sehr gute Handarbeit. Komplimente!
Grazie mille per queste bellissime foto di questi eccezionali modellini, un'ottima elaborazione. Complimenti!
Ciao
niczano
Thank you so much Robin for the compliments !!!
One of the things that worried me most (and worries me) is how I would make the transmission.
Once again the "North Star" is the smallest possible footprint.
I ordered the brass gears from China. Made the first attempt at bogie for Mrs I immediately realized that the biggest problem was the excessive mobility of the axes. To solve this problem I bought some tiny ball bearings in order to make very precise internal bushings.
The last question I asked myself is whether the excessive smallness of the gears would have led to imbalances in the torque (excessive revolutions even with a very low current). Anyhow, I am a ugly lawyer and not an engineer, so the risk of making incredible errors is always around the corner! :D
However today I tested a "prototype" of plasticard truck (the final one will be in 1 mm brass) and I must say that the result is more than satisfactory!
The wheels are from Mr. Luck rp25 7.8 mm (axle 1.5 mm)
https://www.youtube.com/watch?v=RUFs_H-mtQQ
Nic
rene holz
Beitrag von rene holz »
Du bist ein Wahrer Künstler! Echt Klasse Leistung und Tolle Wagen!
Ich möchte gern mehr sehen.
RenesTrampage
niczano
Beitrag von tlrsgerman »
Excellent work! Mille Grazie! Please show more if possible!
Greetings from the German TLRS
Hans-Peter
Hi niczano,
could you please reveal details about motor and gearboxes of your two-axle vehicle drive (worm, gear, module etc.)?
Thank you
niczano
Vielen Dank Rene und Hans-Peter für die Komplimente!
Bodo, klar! Hier sind die Daten:
Kupferschnecke: 0,2 M (1 mm Achse)
Kupferzahnrad: 0,2 M 14T (1,5 mm Achse)
Kugellager: 1,5x4x1,2 mm
Hier sind sie auf aliexpress:
https://www.aliexpress.com/item/4000920 ... 4c4dnj4KU1
https://www.aliexpress.com/item/4000527 ... 4c4dnj4KU1
https://www.aliexpress.com/item/3282354 ... 4c4dnj4KU1
Motor: coreless dual shaft 6 mm Durchmesser und 16 mm Länge
Betriebsvideo:
https://www.youtube.com/watch?v=n-6HJvUSHko
Ciao!
Niccolò
Vielen Dank Niccolò für die ausführlichen Informationen!
rdmodel
Beitrag von rdmodel »
Hallo, mich interessiert vor allem der Motor, welche Spannung, welche Drehzahl und vor allem wo kann man den kaufen und was kostet er.
Hello I'm most interestet in the motordatas. Can you tell me the voltege, rpm and where can I by it and what costs it?
Allerdings eine exzelente Idee mal was aus Holz zu bauen. Ich nehme an es ist Balsa?
viele Grüße rdmodel - Ralf
ich würde mal sagen, es ist dieser Motor:
https://micromotor.eu/Motors/0716-D/
Eine Auswahl gibt es hier, aber ohne 0616: https://tramfabriek.nl/motors.html
niczano
Ja, ich bestätige, der Motor ist 0716 D.
Und ich bestätige auch, dass sie verkauft werden von https://tramfabriek.nl/motors.html
Ich empfehle die Seite, weil der Besitzer Sven hilfreich und sehr korrekt ist!
Dies sind die spezifischen Daten:
rdmodel
Hallo, alle zusammen.
Danke für die Info. Nach 12V Minimotoren suche ich schon lange. Bisher habe ich ja die Vibrationsmotoren aus Zahnbürsten benutzt. Die aber allerdings eine Betriebsspannung von 2V und erfordern eine Vorschaltelektronik. Mit echten 12V Motoren kann man darauf verzichten, das macht vieles einfacher. Gut, die Zahnbürstenmotoren sind noch kleiner 12 x 6 mm. Da kann ich nicht die alten Motoren tauschen.
Im Moment plane ich aber einen Antrieb für den Dresdner A9 Gelenkwagen, da ist viel Platz drin.
Nochmal Danke für die info. rdmodel - Ralf
niczano
Einige Bilder der Updates:
Alle Autos sind motorisiert und veröffentlichen bald ein Video mit der Bewegung jedes einzelnen!
Link um größere Fotos zu sehen:
https://ibb.co/gzFXqpf
https://ibb.co/86rhtnQ
https://ibb.co/jMXHpTB
https://ibb.co/9Yh4Kk2
https://ibb.co/02Fccfp
https://ibb.co/GvhPNgN
https://ibb.co/Yc7BFVy
Nic
