Shapeways - Materialwechsel
Dante Schuggi
Beitrag von Dante Schuggi »
soeben habe ich einen Newsletter erhalten, nachdem wenn ichs richtig verstehe das Material FD nur noch bis zum 14.04. 23:59 ;-) bestellt werden kann. Danach neu gibt es ein Material FXD das besser als FUD sein soll.
Vielleicht interessiert es ja jemanden.
Mit Grüßen Kai / Dante Schuggi
"Dear Shapeways Designer,
Here at Shapeways, we are constantly looking for ways to improve our material offerings to be more enabling, better and faster for you. As a Frosted Detail Plastic designer, we are writing to let you know about upcoming changes in our materials that will affect products you have made and/or are selling in your Shapeways shop.
What's happening? On April 15th we are:
Introducing Frosted Extreme Detail (FXD), with a higher resolution than Frosted Ultra Detail (FUD)
Retiring Frosted Detail (FD); FUD will remain unchanged
Renaming the Detail Plastics materials Acrylic Plastics
What does this mean for you?
If you would like to order your designs in FD, please do so by April 14th to ensure your FD order goes through, as the transition will happen on April 15th. As noted on our Material Status page, we have added 4 days to our expected production time for FD in anticipation of high demand.
Designs that you’ve printed in FD will not go away, and can be ordered in either FUD or FXD. We are updating success rate metrics so successful FD prints from the past will count towards FUD and FXD.
If you have a Shapeways Shop, customers will no longer be able to order your designs in FD after the transition. Products previously available only in FD will no longer be for sale unless you enable another material like FUD or FXD (when it becomes available.) If you have multiple products, the Pricing CSV Wizzard makes it easy to update materials and pricing in bulk.
Where you currently see Detail Plastic material names, you and your customers will see the Acrylic Plastic names. White Detail becomes White Acrylic, Black Detail becomes Black Acrylic and Transparent Detail becomes Transparent Acrylic.
Why are we doing this?
Frosted Extreme Detail has a higher resolution than Frosted Ultra Detail, decreasing the layer height from 29 to 16 microns (the shorter the layer, the higher the resolution). While more expensive to produce, thinner layers means unprecedented detail and surface finish, sharper edges, less stepping, and stronger models. It’s perfect for the most demanding miniatures, figurines, and molds and masters for casting.
Frosted Detail is a fragile material that often breaks during 3D printing, requiring reprints that make the process costly and slow. Because it is printed enclosed in support material that is difficult to completely clean, it's also hard to give you the quality you deserve. Unfortunately, after trying hard to improve the process, we've decided to stop production and focus on better alternatives for you.
Finally, we are renaming Detail Plastic to help reinforce that it is stronger but less detailed than our Frosted Detail Plastic.
If you have questions or concerns, please contact service@shapeways.com.
Kind Regards,
The Shapeways Team"
Re: Shapeways - Materialwechsel
Hallo Kai,
danke für die Info, die Konkurrenz lässt grüßen. Ich denke mal, über erste Erfahrungen wird hier bald berichtet werden. Dünnere Lagen verlängern den Fertigungsprozess. Mal sehen, ob der Preis alleine von der längeren Fertigungszeit beeinflusst wird, oder auch geringere Beanstandungskosten bei FD gegen gerechnet werden.
Bisher habe ich bei SW Gehäuse ausschließlich in FUD bestellt und im vergangenen Jahr die Erstlieferung immer beanstandet, es kam auch bei Ersatzlieferungen vor.
Für jene, die die in FXD gedruckten Gehäuse als Urmodelle für Gussmodelle verwenden wollen, kann es eine interessante Alternative sein.
Hallo zusammen
ich würde mich sehr freuen, wenn FXD Material beim Bastler fettfrei ankommen wird.
Die 'Druckkammer' wurde mir als deutlich kleiner als beim bisherigen Material benannt. 00 Doppeldecker und manche 00 Eindecker sind damit in einem Stück nicht mehr herstellbar. Der H0 Sektor von Festland-Straßenbahn-Eindeckern wird davon allerdings kaum betroffen sein.
Mark Casson berichtete, daß beispielsweise für ein 88 Euro FUD Gehäuse aus dem Bereich der Hobby-Entwerfer in der FXD Ausführung € 130 zu entrichten sind.
Ich habe leider schon einigen Bruch mit FUD Material erlebt. Sekundenklebstoff hilft zwar heilen, doch beim Umgang mit dem Material ist Vorsicht angebracht.
Gleichwohl, warten wir noch ein paar Tage, dann brauchen wir nicht mehr in die Glaskugel zu schauen.
